dougrainer
Jun 30, 2022Nomad
There are 3 systems
1. Hyd Jacks
2. Hyd Jacks AND air bag leveling
3. Air bag only leveling
4. The advantage to air bag leveling is you never have to worry about the ground situation(sand/dirt/mud) for the jacks to sink into. Both Air Bag and combo Jack/Air usually have a 12 volt air pump. Once you turn the Motorhome OFF and have leveled, the electric air pump will continue to air up the bags as they lose pressure and this will also cause the system to continue to keep you level.
5. You don't state what model Monaco, but usually the Hi line signature with Tag axles had the air only. The less expensive Monaco's had Air/Hyd jack. Doug
PS to your other question, Air bag and Hyd jacks have almost the same amount of lift available. The BIG difference is, with Hyd, and your site is very uneven you can install wood blocks under Hyd jacks to gain more lift.
1. Hyd Jacks
