dougrainer
May 03, 2020Nomad
Get to the pump. On the top of the pump system are solenoids. You will see a LARGE battery type cable to a large post on the Solenoid. THAT should have engine voltage(12.9 to 13.8 volts). If NOT, then you have a loose or corroded supply voltage from the batteries. IF you have Engine voltage, then have someone activate the system and READ the voltage on the other large post on the solenoid. This post has the cable from the solenoid to the Pump motor. IF you have the same voltage on both sides within 1/2 a volt, then you motor is bad. Good news is, Powergear pump motors can be rebuilt by a Starter/ Alternator local shop rebuilder. Doug
