All sound like very logical explanations and they make sense. But why would the engineers, the same folks that tell you not to raise the wheels off the ground, engineer and attach them in a way that you can? More to the point, allow them to lift the coach off the ground but be under-engineered in way to allow for lateral failure. And why does the auto level feature ignore this "rule"? I've had mine lift off the ground in auto mode. Hydraulic rams for the most part aren't terribly expensive or complicated. Beefier ones could be installed pretty easily to prevent this type of failure.
