Dead_Head's avatar
Dead_Head
Power Outage
I have a 2003 Four Winds 31P. The coach has been laid up for a few years. I seem to have lost electrical power on the passenger side of the coach. The outlets on the drivers side all work.
Any suggestions? I checked all the fuses and breakers and all are good. The outlet above the sink says that the circuit is GF protected, but the GFI breaker has not tripped. I cannot find any other GFCI tied into that side of the coach. I wrote to Thor and they do not have a wiring diagram for the coach.
Thanks,
  • Odds are you have more then one GFCI receptacle. It could be in galley, bath or all most any where.
  • DrewE's avatar
    DrewE
    Explorer III
    Also, if you haven't done so already, try flipping the breakers off and then on. Some breakers look like they're on even after they reset.
    If your motorhome has a 50A electrical connection, check that both legs of your supply have power.
