FIRE_UP
Nov 27, 2013Explorer
Well Gang,
This is all about COMMON SENSE! It doesn't take a rocket scientist to judge just how much pressure is needed for a given job or, just how close or far away from a surface you need to be to accomplish a purpose. You can use a 3000 psi pressure washer on any surface you'd like as long as you don't get close enough to do damage. It's all about accomplishing your goal without issues. As you can see and read here, some do it and some are really advocates against it.
And yes, just about 100% of the detail crews, at any campground/RV park that allows them, use a PRESSURE WASHER, with few exceptions. If you watch them, they don't get close to rubber seals in windows, graphics, and anything else that can possibly either let water infiltrate, or be damaged by the higher pressure. The MAIN reason that they use them is water control. The can do a good job of rinsing, getting all the soap solution off without creating the Mississippi river in the middle of the camp ground.
And that's the primary reason that most campgrounds will NOT allow for RV owners to wash their own rig. Many of you are smart enough to use a nozzle that controls "on-off" to keep from flooding the entire campground but, some, will just let the hose flow while they soap down their machine.
Anyway, a pressure washer is perfectly safe, as long as the user is wise in its use.
Scott
Scott
38,782 PostsLatest Activity: Sep 19, 2026
