HOM wrote:
Hi MM,
So of the currently in business coach companies the Monaco Dynasty is the only one with a Semi-Monoque chassis? Unfortunately it also has the MaxxForce diesel and I will pass on that! Give me a Cummins any day!
You had mentioned that you were only interested in used coaches. The upper end Monaco products had semi-monoque chassis's. The MaxxForce wasn't put in until later on after Navistar bought them. They used the original Monaco chassis and Cummins's engines for a while before they switched to their own engines. I, too, would not want a MaxxForce engine.
The new owner's of Monaco are using the Cummins engine.
MM.
