jmmymack
Dec 10, 2013Explorer
My coach batteries are two 6v wet cell hooked in series. I have measured the voltage at several locations. Directly on the terminal posts, at the terminal on the electrical control module (marked coach), as well as the output terminals of the converter. I have also measured the electrolyte with a hydrometer to determine the level of charge. I have the plug in wizard to monitor the battery voltage and switch to the various charge modes. I have also removed the converter and hooked it direct to a partially charged battery and measured the voltage at the converter with and without the battery load. Without the battery connected I get around 13.8 vdc with a digital meter. When I connect the battery, the voltage drops below 12 vdc. I can hook up a simple 12v automobile charger to the coach batteries and get favorable results (the batteries charge) The simple fact remains, the converter is most likely faulty; both the original and the replacement.
I am pleased to know others are not experiencing the same problem with the Progressive Dynamic unit. I was probably unfortunate to get two bad ones in a row. My new converter will arrive in a few days and pass on the results. Thanks for all your comments.
38,782 PostsLatest Activity: Sep 02, 2026
