wildmanbaker
Dec 10, 2013Explorer
There are 2 reverse polarity protection fuses on the hook-up end of the converter. Check to make sure they are not blown. If they are, something is not hooked-up incorrectly. With the battery disconnected and the charge wizard disconnected, the output voltage should be 13.5 volts DC. If not and the fuses are good, the converter is bad.
38,782 PostsLatest Activity: Sep 02, 2026
