bukzin
Dec 15, 2013Explorer
wildmanbaker wrote:
There are 2 reverse polarity protection fuses on the hook-up end of the converter. Check to make sure they are not blown. If they are, something is not hooked-up incorrectly. With the battery disconnected and the charge wizard disconnected, the output voltage should be 13.5 volts DC. If not and the fuses are good, the converter is bad.
13.5 volts seems low.
Don't some of the battery mfg's (Trojan, etc) require 14.7 or so?
Do most of these better chargers have owner adjustable outputs
to raise the voltage?
38,783 PostsLatest Activity: Sep 22, 2026
