jmmymack's avatar
jmmymack
Problem with Progressive Dynamic Converter
Hello, I am new to Open Roads Forum. I have owned a 99' Fleetwood Bounder since new. I am curious to know if other members have experienced charging problems with their Progressive Dynamics AC to DC Converter Charger. Since new, mine has never kept my coach batteries charged when hooked up to shore power. Progressive Dynamics replaced the original with a repaired unit and it also failed to keep the battery charged. I have bench tested the unit (hooked it up to a battery directly) and it still failed to recharge a known good battery. I have ordered a replacement charger (different brand) and plan to dispose of the original and replacement converters. By the way all my relays (aux and isolation relay) are working correctly. The coach batteries are good; going on my third set since 1999.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    I will make two comments here.
    First a few questions:
    HOW are you measuring the charge on the batteries? And where are you measuring.
    Next, What kind of batteries (Flooded wet cell (GC-2) Maintenance free, AGM, other).
    Now:
    The charge wizard is programmed to charge FLOODED WET CELLS, the "Full" Voltages for other types are very slightly different, and depending on the type, it might not do the job as programmed.. NO, I do not know how to modify the program (Well, actually I know how.. but there are some details missing) but it can be done.
    Second.. There are several ways to measure the battey state of charge, ONE of them is very accurate (Hydrometer) the rest,,, Not so much. And even with Hydroometers. There are good ones and ... Not so good ones, and PURE JUNK ones.. I've seen/used all 3.
  • RoyB's avatar
    RoyB
    Explorer III
    My Progressive Dynamics Converter/charger puts out the required SMART MODE charging modes of 14.4VDC-13.6VDC-13.2VDC with the proper DC amps capacity when required to keep my deep cycle batteries properly charged. It is almost automatic and all I do is occasionally check battery water levels an keep tabs on my battery bank charge status.
    If you can measure the smart mode charging modes for your particular battery bank then your converter/charger is most likely operating ok.
    My PD9260C 60AMPS converter/charging setup has been functioning great for the past five years.
    Roy Ken
  • My other brand quit working and replaced with Progressive Dynamics converter and have had no problems in the 1 1/2 years I've had it. Went from watering every two weeks to monthly check and have only added water once in 18 mos.
  • I put one in my rv a progressive unit no problems ,charges better than my old unit. two yrs back.
