enblethen
Aug 28, 2014Nomad
Make sure that the drain is solid and actually leaks water under the rig. A plugged lower portion could allow water to drip into operating components.
Water heater should have a small collar that is slide toward or away from the gas valve and orifice. Make sure that the burner tube is coming straight off the orifice so gas goes through the burner tube center. Suggest cleaning the burner tube. The critters like to build webs and nests in them.
