wildmanbaker wrote:
If it is a 2012, it should still be under warranty, and should be corrected by either Fleetwood, or Cummings. The starters do hang-up on the 5.9 series engines. They run about $200. at most part stores, and is very easy to change from underneath.
good luck and let us know how it works out.
Good to know. Thanks! I did call the freightliner help number but they were too busy and by the time they called back, I wasn't at the MH anymore. I did discuss the problem with the lady but she was as dumbfounded as I was. I plan to call them again tomorrow when I'm there again.
