Buster52's avatar
Buster52
Progressive power converter problem pd-7648
I have a Progressive that I believe is giving me problems. It acts like it is not charging the battery. Opened it up and find 12 volt power to about 2/3 of the fuses. But the side that powers the heater, pump and battery is dead. I understand it maybe the pc board that I cannot find a replacement for. Is there something else that maybe wrong with it? Does anyone know where I can find the board, or what can I replace the 12 converter with? Any help?
Thanks
Buster
  • I want to thank all the advice I have received. I have fixed the problem with a tooth pick. That is right a tooth pick. That was after removing to unit and putting it on a table. The battery charger part is a SCR that is controlled by a circuit board. The board had power but it wasn't making it to the SCR. A squirt of contact cleaner and running a tooth pick through the connector pins and now it is alive. And next thing is putting it back in and connecting all the wires. If it goes out again I will just replace it. Thanks Again
  • If you want to make friends with communist countries buy a WFCO. If you want a good converter dont buy a WFCO, buy something better like a new PD. Some upgrades come with a new fuse panel.
  • That old PD-7648 is a 1970's technology.....
    In your 1989 RV it's 25 yrs. old.
    Time for an upgrade....new converter.
    As suggested.......talk with Randy at Best Converter LINK
  • I looked for a direct replacement and found none. I can get manuals on it but cannot find parts or replacement for it.
  • Maybe this will help
    Manual
    Some of these older units have two outputs, one clean and one dirty.
    I would suggest getting a direct replacement converter section from Best converter. It could save a lot of headaches.
