olfarmer wrote:
You should take it to an authorized LP service facility and have it checked. Don't mess around with LP gas, it is just too dangerous if the equipment is malfunctioning. I would not remove the bleed valve if there is LP in the tank, if the restriction would break loose it will shoot very cold, very flammable liquid out under high pressure!
EXACTLY! I would never, EVER take anything propane related to an RV dealer! They are probably clueless for anything other than filling the tank or performing a system leak check.
If there is a problem of any kind with the tank or cylinder, get it fixed!
