Daveinet
Mar 14, 2014Explorer
Francesca Knowles wrote:Technically he is right, but I think people are misunderstanding. The potential problem is the cheap piece of junk that Dometic and Norcold make their cooling units out of. We all know about how the boiler tube is too thin, and can easily overheat. When it does, the pipe bursts, which is a problem because what comes out of the pipe will burn.Dick_B wrote::h
Bill of Bills RV in Ventura, CA does not recommend having the fridge on when traveling. As I remember if the pipes clog and the flame is on there can be trouble.
What "pipes"? Certainly he couldn't mean the propane "pipes", since if those clogged the flame would go out. If he meant the fridge coolant tubes, they're much less likely to clog when the rig's in motion. And even if they do clog, the outcome would just be loss of cooling.
I think Ol' Bill the Dealer was givin' you a standard "CYA" answer to the question.
Now as much of that is fact, the problem is that is a potential issue regardless of if you are driving or not. The only bad part about driving is that if it does blow, you will need to pull over, which reduces the time you have to get out of your RV before it burns to the ground. Even if it does not catch fire, you have a severe ammonia problem, and will need to vacate the coach for a while - ask me how I know.
38,777 PostsLatest Activity: May 19, 2026
