dougrainer
Mar 22, 2014Nomad
liborko wrote:
A flame needs oxygen to burn. If it is burning it is getting oxygen. If it is getting oxygen, it can get explosive mixture of gases as well.
I guess we will never agree on this issue. I travel with all propane appliances OFF and propane tank shut-off. When I have to have fridge running while driving, I run it on inverter. You do as you please. Signing off.
What happens when you have someone run into your RV at the LP tank????? You can do what you want. But, to state that having the LP system ON when traveling and to have the LP refer ON when traveling is dangerous is PLAIN wrong. Possible problem? Yes, but with Millions of RV's traveling with LP systems ON and the refers ON for over 50 years, you would think that there would be scores of reports about BAD things happening and the truth is, there is NOT. What about dual fuel(LP/Gasoline) Cars and trucks and vehicles that run on LP or CNG. What is your response to those vehicles. Doug
38,777 PostsLatest Activity: May 19, 2026
