DabooExplorerAug 20, 2013propane fridgeHaving a problem with the propane side of the fridge not working..read where if you are above 5000 feet elevation, the propane side would probably not work and recommend using electric..if you don't h...Show More
BillofPAExplorerAug 20, 2013Our propane frige worked just fine when out west above 8000 feet. Never had to use electric because of altitude.
Related ContentTroubleshoot fridge problem...Norcold Model 611 Fridge problemRunning a fridge on propane?Dometic 2-Way fridge repair issuesPropane fridge not working as good
