Daboo
Aug 20, 2013Explorer
propane fridge
Having a problem with the propane side of the fridge not working..read where if you are above 5000 feet elevation, the propane side would probably not work and recommend using electric..if you don't h...
Daboo wrote:MountainAir05 wrote:
As stated clean if not been done and have the pressure check. I live at 4500 and camp at and above the 9000 and have never had a issue. You did not say why the propane did not work. That might help get you a better answer. Does it light or will just not stay lite.
it won't stay lit..tried it this am and it burns for about a minute and then goes out.
