Daboo
Aug 20, 2013Explorer
propane fridge
Having a problem with the propane side of the fridge not working..read where if you are above 5000 feet elevation, the propane side would probably not work and recommend using electric..if you don't h...
Daboo wrote:
Having a problem with the propane side of the fridge not working..read where if you are above 5000 feet elevation, the propane side would probably not work and recommend using electric..if you don't have electric available..guess tough luck..anyway has anyone else read the above 5000 feet thing...thanks.
