Paul_James's avatar
Paul_James
Propane Furnace Exhaust Fumes Inside Coach
Hello All,
I’ve been looking to buy a 2015 Winniebago Vista 36Y. I live in Northern NJ and couldn’t find one locally. I located one at Ray Wakley’s RV Center in North East, PA, some 6 hours away, and liked the unit very much when I saw it. While walking through it, I asked the salesman to turn on the furnace, and when he did, the coach filled with smoke, not so you couldn’t see, but enough that we had to turn on the fan and open the windows.
The salesman immediately called their top service guy in, he didn’t think it was a big deal, and said new coaches often had coating that had to “burn” off, and as part of their setup, they run all appliances for 6 to 8 hours. It wouldn’t be a problem and they would fix it.
The salesman offered that the rig had been on the lot for over a year, and maybe an insect had nest in the exhaust. It’s a 2015 but the MH is new.
Do these explanations sound logical? When he first turned the furnace on, I went outside to feel the exhaust, to see if was getting hot and it was, and the exhaust felt forceful. So I’m not so sure about the insect nest theory. As to coatings needing to be burned off, has anyone ever heard of this. Is this something I should be concerned about? Should unburned coatings be filling the inside of the coach?
The generator was also running really rough, it’s an Onan 5500. I’m figuring stale gas, but could the carb be gummed up after a year of not running much and I’m sure no Stabil was added.
I like everything else about the rig, the price is right, and I had a really hard time finding a 2015 close by. I put a deposit down, and the dealer is assuring me all will be made right. But I certainly don’t want to be in a coach with propane fumes and would like some advice as how to proceed.
Thanks.. Paul
  • I've dealt with Ray Wakley several times and they are a reputable honest dealer, in fact there one of a few Winnebago GOLD STAR dealers/service centers in the North East. I would not hesitate buying a unit from them.
  • All new furnaces need to be burned off. And, after they sit for a while, the dust needs to burn off.
  • YES very normal for 'new' furnace to smell when first fired off.
    YES there is an.... oil coating on the metal.....used during mfg. process
    IF it was CO the CO Alarm should have gone off if it's battery was in and good
    CO is from combustion of the propane.......propane would be that 'bad egg' smell and the LP Detector should have gone off if there was a propane leak.
    Furnace heat exchanger would have to be cracked in order for CO to leak inside RV
    Made sure ANY/ALL Items found that are not right during your walkthru inspection are fixed BEFORE you pay them anymore monies.
    They are all smiles and handshakes when getting your money and then don't know you afterwards -----just saying. GET IT IN WRITING
    Like Judge Judy says "If it isn't written it doesn't exist"
