dougrainer
Jul 25, 2015Nomad
pconroy328 wrote:Jim@HiTek wrote:
Down near the floor in the kitchen is an electronic propane gas detector.
Just asking - I thought these auto-shutoff systems had been gone since, um, 2005 give or take?
I thought I read that somewhere.
Am I mistaken?
Forest River still uses the Auto/ electric solenoid LP systems. MOST RV makers stopped using them because of failures of the system. But if you get a trickle of LP that means the solenoid is opening. IF the LP appliance is in a slide room the possibility is the rubber LP feed line may be pinched because it was not installed correctly. THAT usually causes this type problem. Doug
