77rollalong
Mar 31, 2018Explorer
One problem with propane is its boiling point, your tank pressure varies directly based on the tank temperature. AT 0 deg F you only have a tank pressure of 24 Psi, and if you draw off vapour faster than the propane will Boil the pressure will drop even more. the only way to get the tank pressure up is using a tank heater. At 60 deg f the pressure goes up to 92 Psi and will boil a lot quicker.
