TrapExplorerOct 19, 2013Propane ProblemWe had our large 39 gallon propane tank filled a week ago on our class a, since then our propane has worked sporaticly. The BBQ starts works for about 8 minutes then shuts off. We can't light the cook...Show More
Brodie3AzExplorerOct 19, 2013Sounds like you have a restriction of some sort in the line.Is the rubber hose kinked/pinched?Is the valve open all of the way?Did some kind of foreign material get on/in the hose end or inside the tank fitting?
Related ContentPropane problemPropane ProblemAtwood water heater problemTroubleshooting Propane ProblemTroubleshoot fridge problem...
