We had our large 39 gallon propane tank filled a week ago on our class a, since then our propane has worked sporaticly. The BBQ starts works for about 8 minutes then shuts off. We can't light the cook...
Could be moisture in the tank as well. It'll freeze and plug the line as it leaves the tank and pressure is reduced. Pressure inside the tank prevents the moisture from freezing.
