derh20
May 24, 2015Explorer
Like DrewE stated, the simplest solution is to instal a line from your RV Propane tank to an area outside your MH where you typically grill. Using a quick disconnect, you then plug your hose to the connector on the side of your MH where the lead is. No bottles to lug around and you don't run out of propane in the middle of preparing dinner. Of course you do need sufficient propane in your RV propane tank.
38,769 PostsLatest Activity: Apr 03, 2026
