Wshiley
Jul 12, 2017Explorer
Propane Tank
How many of you had a propane tank go bad. We have chased a propane leak for years with many different technicians giving their two cents. Replaced the fill valve. Replaced the regulator. Replaced the...
Wshiley wrote:
How many of you had a propane tank go bad. We have chased a propane leak for years with many different technicians giving their two cents. Replaced the fill valve. Replaced the regulator. Replaced the gauge. And now replaced the internal pressure valve. Of course each time the tank would need to be purged. Apparently we have finally solved the leak by replacing the entire tank. Apparently where the tank sits behind the front wheel stones fly up and chip away at the tank seems. A pin hole has been the cause for years. Not sure why the technicians couldn't find this originally but most chase propane leaks with soapy water and not the proper tools. So if you have a propane odor make sure they check with all the correct tools.
