mt-ed's avatar
mt-ed
Pros/cons of class B and P/U slide in?
I'd appreciate any comments. Which would be best to purchase, a class B rig, or, a new P/U and slide in camper rig? If a person needed to purchase a new P/U to properly support a larger slide in camper, wouldn't it be just as good, if not better, to just get a class B rig? Thanks in advance....oh.....if you need more information to answer this, please post them as well!!
  • The 2 posts above are pretty accurate but I want to expand on what they wrote. When we decided to get an RV more than 10 years ago I researched small Class C's, pickup campers, and Class B's.
    Pickup campers range from lightweight popups with minimal facilities to large models that approach the liveability of a B. A 1/2 ton PU can easily carry the popups and is your best bet for off-roading. The larger, more comfortable campers require at least a 1 ton truck and most require dual rear wheels. They are not so great for off-roading because of their height, width, and high center of gravity. Overall, truck campers are great for people who already have a pickup truck or need one for other purposes. I decided against a pickup camper because I didn't need a pickup and because I didn't like the cabover sleeping arrangement.
    I didn't see any small Class C's that had a floor plan that I liked. That, plus the generally poor construction quality of C's, nixed them for us.
    That led us to a class B.
  • I don't own either but, I think SoCalDesertRider gave you the best answer.
    How will you use the RV and how often?
    Will it be your daily driver?
    The B's are nice. But so is Four Wheel Drive if you need it.
    There is a lot to think about. Take your time to decide which is best for you and your situation.
  • It depends on what you want to do with the RV.
    Class B camper vans are usually 2wd, with low ground clearance. If you like to go off road, a 4wd pickup with a camper in the bed is a better choice. Sure, there are some 4wd vans out there. They are rare and very expensive, compared to the myriad of 4wd pickups available.
    A pickup and camper is a multi-use vehicle. Drop off the camper and you can use your pickup for all sorts of things that you can't do with a camper conversion van. This is important particularly if your pickup is your only vehicle.
    If you are looking for a dedicated RV-only vehicle, for mostly on-road use, the class B camper conversion van may be your better choice, or a small class C van-based motorhome.
