Yahooligan
Mar 12, 2013Explorer
Alright, got it home! Had a minor incident on the drive home (Turbo pipe coupler blew off up a hill, got it back on and tight, made it home no problem. Replacing the couplers is now on the to-do list).
So far the only questionable appliances are the roof A/C units and the stand-alone ice maker. I spent a while playing with everything, exploring under/behind things, etc. I'm amazed that everything works, honestly I was expecting to have to replace random things but both furnaces fire right up, the water heater fires right up, etc.
I'm also pretty impressed with the overall build and design of the coach, I can access everything with relative ease for inspection/repair/replacement, including the plumbing. Seems to be a very well planned-out coach, well built and designed to be serviceable.
One thing I haven't been able to figure out yet, there's an electric air compressor mounted on the frame just behind the rear axle. This compressor is on the entire time that the ignition is on whether or not the engine is running. Should it be running all the time? I wouldn't think so, but I haven't looked into it much.
Things that don't work/need to be fixed...
The clearance lights don't come on with the headlights. Previous owner says they work intermittently, so need to trace that down.
Need new coolant and oil pressure gauges in the dash. The rear gauges work fine, the coolant gauge is jumpy at random. The oil pressure gauge seems to be off by about 10psi compared to the rear. At idle and up to temp the front reads 7-10psi, the rear is solid at 20psi.
Need to replace all of the storage door locks and some of the lift arms
There's a relay that clicks under the dash every 10-15 seconds, every time it clicks the volt gauge dips slightly. Only happens with the engine running, no switches on the dash are on and everything seems to be working fine so I have no idea what it could be for.
The exhaust cross-over flex hose (Goes under the oil pan) has cracked at a couple of the seams and is blowing exhaust. Easy fix, just need to measure to get the right replacement.
Got the new tires on (Toyo M122) and it rides nice, they used bead balancing and I have no vibes. Score!
Seems to be happiest running about 60-65mph, drops down to 50-55 on some of our steeper local freeway grades. Boost peaks about 25psi under load at those speeds.
38,768 PostsLatest Activity: Nov 21, 2015
