Tom_Barb
Jan 06, 2018Explorer II
smj wrote:
Blue Ox makes / made a surge type brake system, also. It fits in between you receiver and tow bar. It works very similar to the Ready Brake. I have both but have never used the blue ox. ( I bought it when I needed a replacement quickly for my ready brake . The ready brake was repaired very quickly, so I didn't need to rework my setup to use the blue ox. It's still in the box).
I use the ready brake to flat tow my 4 door jeep rubicon on 35" tires, about 5000 lbs. It works really well. I have towed over and within the Sierras and the Rockies many times. The jeep brakes aren't applied when using only engine braking down a long grade. They don't activate unless you apply moderate or strong braking of the tow vehicle. I think its a great solution and doesn't require extra parts to be installed in the driver's floor area every time you tow. In fact its a very simple mechanical device with very few parts to fail, no electronics at all. Only special consideration is the tow bar must be within 2" of being level when the rigs are on level ground. This prevents binding of the brake mechanism.
As far as OP, I have a 3.5" lift and 35x12 tires with no wear problems from towing over 10k and 30k+ on this set of tires- KO 2 .
good luck,
Stuart
We use one of THESE
38,769 PostsLatest Activity: Dec 31, 2014
