Cider
Jan 17, 2018Explorer
Post to original question about key in ignition. I believe, but not positive, that 2009 was the last year that the steering wheel lock was involved. I may be wrong, but best bet is to check owners manual, or, take key out of the ignition and turn steering wheel lock to lock to see if it locks up. If so, need to leave key in ignition and may also have to disconnect battery as part of flat towing the rig. Our is a 2008 JK and we use a "dumb" key to keep wheel unlocked with a built in battery disconnect switch installed. Hope this helps you on the original question.
38,769 PostsLatest Activity: Dec 31, 2014
