Snowman9000
Feb 05, 2017Explorer
tnedator wrote:
I forgot that FR puts Azdel in the walls, it's just the luan on the roof vs. Azdel that is different.
Thanks for the info. I'm curious if there were any things in particular that you at the factories that has you suggest I go with Nexus if I want the Ford?
Also, I think I'm remembering correctly that the Forest Rivers in the size I was looking at didn't have retractable steps. I wonder if that means they are lower to the ground?
Nexus uses steel outside storage compartments. FR uses poly tubs screwed to whatever, cheaply. I would not be shocked if some day one of ours ends up in the ditch. :)
The FR's have a lower internal step so they don't need the external. I like that.
38,782 PostsLatest Activity: Aug 31, 2026
