pnichols
Jun 14, 2018Explorer II
Bumpyroad wrote:
are 8 inch boards wide enough to support the edges of the tire treads?
Yep.
BTW #1 - I fit all 5 step blocks plus the 5 other wood pieces in only one of our 2005 model year 24 foot Class C's seven outside storage cabinets! They don't build/design em' like they used to.
BTW #2 - The tread on my Class C's non-stock 215/85/R16 tires is "slightly" narrower than the tread on the stock 225/75/R16 tires that came on it because I wanted a taller tire for better ground clearance without having to change rims to fit fatter tires ... or reduce spacing between rear dual sidewalls by using fatter tires on stock rims, thus reducing cooling air flow between the tires in the dual sets.
