Hank85713
Dec 29, 2014Explorer
If you want an rv generator go to craigslist and look 1st. Lot of them generealy posted there. You will need to have someone knowledgeable check the thing out however as these can be temperamental and have issues that can be $$.
I mounted a champion generator on the back of our TT was actually pretty easy if ya can weld or know someone who can. Its primarily for non camping use (AC while travel in hot regions, roadside stops etc) could be used in areas without prepared campsites (again roadside forest settings). It has a 63 db noise level at 25 ft so not bad and it is an rv develeoped gen. But for you I think CL is best bet
38,778 PostsLatest Activity: Jun 10, 2026
