Matt_Colie
Dec 29, 2014Explorer II
aznmatthewpride wrote:
Hi guys, I am new to the RV world, just bought a 1984 Ford Econoline Jamboree. Here's my questions regarding of getting a generator, is there any size differences (actual dimensions) for a RV? I have seen one online with 4000 watts from duromax only $290. Does it fit? Thank you
OK Matthew (nice name),
The First thing that you have to know is that the chassis name plate (Ford or Duramax in this case) has very little to do with the house on the back (here after referred to as the coach). What you have is a Jamboree on a Ford E-(something) cut-away. (A Class C by convention.) Jamboree is a Fleetwood nameplate, so go there to look for people with hands on experience.
What you need first are real measurements. Most RV units are short vertical, but there are other restrictions as well. Those made for RV service are on good mounts and made to be serviced from outside without too much difficulty. That makes all the difference in the world.
I suggest that you measure the generator space you have, go measure the subject unit and see if it has a chance. If it does, then go to all the Fleetwood sites you can find, (there is a group at irv2.com/fleetwood) and there are probably others. Those people should be able to give you real answers.
Matt
38,777 PostsLatest Activity: May 24, 2026
