Bordercollie
Dec 29, 2014Explorer
As suggested I would carefully measure the generator compartment and compare it with dimensions of compartments of other newer rigs that use the common Onan 4000watt "micro quiet" generators. Find out if Fleetwood built-in wiring and breaker/fuse box, remote start and other provisions for mounting and using an RV generator. Modern rigs have a transfer switch built in to switch from shore power to generator power, others simply plug the shore power plug into a receptacle on the side of the generator to get generator power into the rig.
Fleetwood may be of some help supplying a wiring diagram and advice. Contact local RV services to find one that is experienced in installing genertors in old rigs. As menttioned, use of RV genertors and utility generators in RV parks and following rules and etiquette are a sensitive subject. Use of RV generators are handy to run your microwave for lunch and your TV for weather reports or underway to run the roof AC in summer heat.
38,777 PostsLatest Activity: May 24, 2026
