pianotuna
Jan 25, 2015Nomad III
Hi,
I'd suggest placing the inverter as close to the inverter as humanly possible without it being in the same compartment and using a minimum of #8 wire (thicker would be even better).
Run a 120 volt line to where you need the power.
Remember that 400 watts on the inverter may translate to about 40 amps of draw @ 12 volts on the battery bank.
38,766 PostsLatest Activity: Jan 10, 2026
