tenbear
Jan 25, 2015Explorer
If the inverter is wired directly to the battery with no connector in the circuit you will be limited only by the wire size and any terminals used to make the connection. You should be able to run the full 400 watts, about 40 Amps.
Pianotuna is absolutely right. Keep the wire between the battery and the inverter as short as possible. 10' of two #8 wires will cause a 0.5v drop. 5' would only have a 0.25v drop.
38,766 PostsLatest Activity: Jan 10, 2026
