wtfjr
Aug 19, 2014Explorer
mci7 wrote:
Still the question WHY do you want to run the generator while plugged into the post ?
IF it is to try to run both A/C units, 1 from genset and 1 from the post, that is stupid at best, would guess an different tactic.
Seems the gasoline usage is a large issue, with all the campers you have purchased, money would not be an issue.
If you were at a suitable rv park, they would have 50 amp service I would ASSUME.
At best the max power offered at Sebastian is 30 amps.
Our last two trips there we had to leave early due to their "brown outs".
And all the time there we run only one a/c unit, water heater is on gas as needed.
If their power browns out this time we'd like to stay our booked two weeks & that will explain why we'd like to run the generator. So we have at least one a/c unit & the residential refrig to run.
Can you offer any better alternatives ?
38,763 PostsLatest Activity: Mar 21, 2016
