PUCampin
May 21, 2015Explorer
One important number is the rough in number, or the distance from the center of the hole to the wall. Different toilets have different rough in distances. The Aquamagic 5 has a fairly shallow rough in number making it work in most applications. HOWEVER the Aquamagic 5 is a POS!!! It is made as a disposable, about the only thing repairable is the blade seal. There is no pipe that goes straight down to the floor, but opens to a internal chamber that is nearly impossible to get clean. Mine lasted 2 years and had a seal fail that was not replaceable, I had to by a new toilet. I bought a Style II. Many replaceable parts, easy to work on, china bowl, and no splash chamber. If you can fit anything other than a aqua magic 5, you should.
38,766 PostsLatest Activity: Jan 10, 2026
