mlslcan
May 22, 2015Explorer
Here is a pdf that I found that shows replacements available for a galaxy starlight toilet. I am not sure yours is a thetford or not.
Thetford convesion pdf
From that document I think you will be fine with the one from amazon.
If the flange is 90% off I would remove the current bolts that hold the toilet, drill holes at the right location for the new toilet through the flange and use these bolts that screw into the wood below the flange to hold the toilet.
Bolts
Mike
Edited to make links clickable
Bolts
Mike
38,766 PostsLatest Activity: Jan 10, 2026
