dicknellen
Jun 29, 2016Explorer II
I have a Winnebago Chalet 24VR the same as the 24V Minnie & Spirit. The gray valve is way back and they use an added metal rod attached to the valve. My gray has always been hard to pull due to the metal rod running thru some metal guides. I think you can get to the valve if you get under your Spirit. Have not needed to replace my gray or black valve so don't know for sure. I did get under mine once to check the level sensor wires. Dick
38,782 PostsLatest Activity: Sep 02, 2026
