Sam_Spade
Jun 29, 2016Explorer
F1bNorm wrote:
The problem you're having is the stuck valve, so lets deal with that first. Its probably stuck from lack of use. If you think the tank side of the valve is dry, pour a gallon of hot sudsy water down the sink drain and try to get some of the same on the outside of the valve.
IF.....the problem really IS a stuck ROD, Pblaster should be fine on the metal rod and hard plastic guide for it.
However....we now have a second, very knowledgeable person suggesting that the problem likely is NOT the rod but the valve itself.
But the OP seems to be ignoring that advice.....for some unknown reason.
38,782 PostsLatest Activity: Sep 02, 2026
