dan23's avatar
dan23
Questions about repairs about to begin
My Winnebago Brave was damaged in a wind storm and repairs are about to begin. The RV repair shop gave me a quote for replacing the awning. The OEM awning was an A&E brand, while the repair estimate says Dometic. I asked the shop and they told me the two are "the same." My b.s. alarm wants to know: Are the brands functionally the same or actually the same as in parts from one will fit the other? Is there any other difference(s) I should know? Do the two brands have different quality levels available? My rig was in their shop while waiting for my insurance company to pay and I was going to be out of town for a while, so I went to pick up my RV and found they'd removed the existing A&E from the rig. Red flag?
When the wind ripped the awning frame apart (not the fabric; as far as I could see only three very small holes in the one-year-old fabric before winding it up to continue to my destination where repairs could be done), the arms flipped up over the roof and cracked the fiberglass in the curved area by the edge (each of two about 6" long). I'm considering doing that repair myself to make up my fairly high deductible, using this kit:
http://www.westmarine.com/buy/west-system--fiberglass-repair-kit-105-k-repair-kit--12954095
The kit is epoxy based, which I've read adheres better than resin kits. I have pretty good skills and the tools I'll need: basic hand tools, plus a belt sander and an orbital pad sander. I'm not quite sure of the best way to approximate the color of the 17 year old roof, but at 17 years old... I'm more worried about paint failing to adhere than getting an exact match. Suggestions on color-matching with paint, getting paint to adhere, type of paint to use, or tinting the epoxy welcomed.
Should I drill a small hole at the end of each crack to keep it from continuing or will the epoxy prevent that? Would the epoxy run into the hole that I cannot block from the back side?
Any reason(s) I should NOT do the fiberglass repair myself?
Thanks for any suggestions or help.
