Fiesta
Nov 21, 2015Explorer
2015 40E. Water and drain lines to the slides for sinks and refrigerator run on arms extending under the slides like the supporting arms. They are exposed to freezing. I can shut off the refrig. water supply under the bathroom sink. Have not found shut off the kitchen sink yet. The kitchen sink drain; just don't use it in very cold temps.
There are many holes that need to be plugged in the compartments below the slides, ESPECIALLY the water compartment. Can't drain sewer tanks if frozen, then can't do a dump....
Plug every hole light comes thru from outside. Look under slides.
Disconnect city water hose at faucet outside, drain and put hose in lower a compartment, when below freezing.
Leave some heat on inside.
