truepath
Jan 16, 2014Explorer
I have a 750 watt Vernado that I'm happy with. It does not have a thermostat, but does have two setting. Its main virtue is that it is quiet, unlike many of the other cheap units. If I recall correctly, this heater was not really any more expensive than similar units. When I am shopping for a small heater I always test it out in the store for noise level. I've found that the 750 watt units can keep the B comfortable down into the 40's, but not much below that unless the sleeping area is closed off and then it is fine down into the 30's (assuming there isn't a big wind blowing outside).
38,774 PostsLatest Activity: Apr 26, 2026
