D_E_Bishop
Feb 15, 2017Explorer
The CCI propane detector in our old Bounder had a on/off switch that turned on the detector and actuated a solenoid to allow propane to flow, IF the manual shut off valve was open. For storage I turned the detector off and shut the valve.
The problem with that set up is they "SHOULD" be replaced every 5 years at a cost close to $300.
I believe that Saf-T-Alert has replaced CCI and of course changed the solenoid so you cannot use their detector without changing the solenoid.
While I don't like "qualifiers", here is one, I feel that the five year rule is a CYA rule for the detector makers. I know that there is an element of validity to the suggestion but I have tested 20 year old detectors, both propane and smoke/fire with aerosol cans of gas used by home inspectors to test them. Yes I did that as part of a home inspection for RE buyers or sellers and of course we added the requisite disclaimer that "date of detector installation was unknown".
38,782 PostsLatest Activity: Sep 10, 2026
