Coelacanth wrote:
Removed the motor case. Turned the rotor manually. Motor gear turned normally. Reattached motor and gear to step gear. Turned rotor manually, both directions. Step arm moved back and forth just fine. Motor guts look fine, but I have no idea what normal brush wear looks like? But, the mentioned 94% seem to be on target.
So, next question(s). These servo motor assemblies online look just like what I have. But, are the gears universal? Are the mounting holes? If not, how do I know which item to purchase?
Did I not already mention, to match it up with one that's pictured on Amazon and I do mean exactly. Doing that insures that it will work....
WINDOW MOTORSSTEP MOTORSTypically you can find one and the same for either window or step, with the price being the only difference.
