dougrainer
Feb 24, 2020Nomad
Ramco have them too. They even state such in their on line troubleshooting. Doug
Removal of Arm from Mirror Head
1. Loosen the set screws located on the arm that holds the mirror head in place. (3/16” Allen
wrench)
2. Pull arm off the mirror head. Two aluminum halves that go around the ball stem will be exposed
and become loose. Place those to the side.
3. If there is a plug on the end of the wire harness, an AMP deplugging tool will be needed to
remove that plug. (Be sure to note sequence of colors) Otherwise, remove wire harness from
arm.
wrench)
arm.
38,782 PostsLatest Activity: Sep 02, 2026
