cbshoestring
Nov 02, 2015Explorer II
Ether BAD.
Check the side of your engine for something that looks like this...
You turn the round handle part to the left...it can then be pulled up. That round thingy is attached to a shaft that will "pump" your fuel system. Pump until it gets hard...close...turn righty-tighty.
Then try to start.
EDIT: NOT possible on ALL diesel...you may have to crack open the fuel lines going into injectors...crank to bleed...tighten fuel lines back up.
Then try to start.
38,766 PostsLatest Activity: Jan 10, 2026
