dicktill
Dec 20, 2013Explorer
Econoline424 wrote:
Recently, I have noticed that the temp guage moves toward the "High" mark as soon as the van is warmed up.
Also, after shutting off the van at one point, and restarting the engine, the temp needle moved all the way to the High point, but then came back down to slightly above Normal.
Dumb question, but have you checked that the antifreeze level is full? My vote is that you have:
a) low fluid level
b) sticky thermostat
c) loose wire or faulty temperature sender
Good luck, Dick RT09/10C190P Allegany NY "no more deadlines"
38,766 PostsLatest Activity: Jan 10, 2026
